Export as Step what is Bsplinesurface
11773.5 In reply to 11773.4
Hi Matadem, so if you set WriteAnalyticSurfaces=y inside moi.ini then MoI should write out PLANE surfaces instead of B_SPLINE_SURFACE_WITH_KNOTS.
That's what I did to make the attached version.
Does this file behave better when you load it into FreeCAD?
