Skew/Shear
11758.2 In reply to 11758.1
Hi Raven, you can do it with a Flow using surface to surface.
If you can post your file that would make it easier to figure out what is not set up right.
I think your problem is you're using curve to curve flow which is meant to be be used more like a centerline path, not with closed curves like you have unless the object to deform was like a tube with the base curve and target curves at the centerline.
For this you would need to use surface to surface and not curve to curve.
Here's an example, I placed a plane using Draw solid > Plane (note, not Construct >Planar) , and edited its control points to make the target surface:
Select the object to deform, then run Transform > Deform > Flow and for the base curve or surface select the surface by clicking in this area, note not right at the corner, a little ways in from the corner along one edge:
Click the target surface in a matching spot like this:
That will make this result, set "Rigid" off if you had turned it on before:
EDITED: 8 Jun 2025 by MICHAEL GIBSON
