Need Help migrating Moi from PC to Mac
11757.2 In reply to 11757.1
Hi binfordboy,
> Actually I want to migrate my customized Moi Version from PC to Mac. I located
> the new Folder for app data under Mac "Library
> /Application Support/Moi" and copied all files from the Windows app data.
> But nothing happened. Do I miss something?
You'll need to close and restart MoI after copying the files over. You'll have some stuff in sub folders to copy too like /commands , /customui , and /startup .
> In some of the files are references like:
> var menu = "moi://appdata/customui/ScriptsSorted1.menu.htm";
> what is the right syntax here under MacOS?
It's the same syntax for both Windows and Mac. When it's using moi://appdata that means "look it up in the appdata folder" which on windows will be %AppData%\Moi and on Mac it will be ~/Library/Application Support/Moi .
So you shouldn't need to change these, they're cross platform.
Maybe check that you've got everything copied including sub folders.
