Hi SUIYAN, can you please post the .3dm model file with your object in it?
If you want to work with surfaces you can use Edit > Separate to break your model up into separate unjoined surfaces.
It may be possible that the problem in this case is a display bug and your actual surface is ok. Does it look ok if you export to .obj format?
