Hinzufügen eines Bogens
11753.2 In reply to 11753.1
Hi Ronni, you can draw an arc of a given radius through 2 points currently by drawing a circle of the desired radius centered at each point and then use the Arc Center command.
Like this given these 2 points:
Circles of the desired radius at each point:
Then arc from center point with these 3 picks:
To automate this maybe the arc center command could have a radius field and if you put a value in there it could ask for the start and end point and then let you pick the 2 possible center points.
