Automatic dimension detection future request maybe?
11751.2 In reply to 11751.1
Hi Matadem,
> Is it possible in the future to have automatic dimension.
> so instead of selecting horizontal or vertical or angle it automatically
> set the dimensions so you don't have to choose.
It's actually possible right now by installing this attached DimAuto plugin I just made.
Instructions for installing a plugin here.
That will make a new command DimAuto available (requires MoI v5). The way it works is after you pick the 2nd point for the dimension there are 3 lines that will be radiating out from that point, one horizontal, one vertical and one aligned. Whichever one you are closest to for the 3rd pick will determine the type.
Looks like this:
Hope that helps!
Updated to show warning message if not running on v5.
EDITED: 29 May 2025 by MICHAEL GIBSON
