StraightSnapLineColor V4vsV5 inconsistency
11748.4 In reply to 11748.3
Hi Mik,
> The most clear solution IMO would be to have this setting, ie StraightSnapLineColor in Theme manager.
So there is a theme setting STRAIGHT_SNAP_LINE_ARGB_COLOR for this but to edit it you need to edit the theme's defines.inc file in a text editor. There is not yet a UI control for editing a color that includes transparency.
That theme color will only be used if the value in moi.ini has the default value which is
StraightSnapLineColor=103,0,0,0
If you've customized that value in moi.ini then it will use your custom value instead of the theme's so it will have compatibility with previous versions.
I will set up a STRAIGHT_SNAP_LINE_ARGB_COLOR2 which can optionally be present in the theme's defines.inc file to directly specify the second color to be used for a dark background theme instead of inversion.
