It's marginality, but I've noticed color inconsistency between V4 and V5 version in StraightSnapLineColor of construction line.
Color of this line is controled via .ini file by Drawing Aids / StraightSnapLineColor=255,255,255,0. This is my current setting in V4, where the line is yellow as I expected, because first number is "opacity" and rest of numbers are R,G,B values.
In V5 version of MoI the appearance of construction line is different with same setting - StraightSnapLineColor=255,255,255,0
I set thickness = 20 for better visibility. It's evident from pictures above that dashed lines segments have different length and space among yellow segments are additional filled with Blue color, therefore the construction line with default thickness = 1 is appeared as "white".
I supposed that second color (blue) in dashed line is some interference of Themes setting, but I didn't find any settings in Themes manager.
I'm not sure if it's bug or I have to do some other settings.
Mik
