your thread is a little outside the neck bottle at the ends. It needs to come in a bit.
I would go to the curve cut the place where you have section tapering in then blend that section I would then rebuild the curve to make it one curve. . At that point you can sweep it with your profile and boolean the thread and neck together. once that is done you can fillet it.
