pattern generator in Moi or to import in Moi?
11744.2 In reply to 11744.1
Hi Matadem, in the steps that are listed there, it has step 3 as:
3. Trace the bitmap with pstoedit and export a dxf with potrace
You can probably import that DXF into MoI to get the profile curve, then inside MoI use Construct > Extrude to extrude it into a solid, then Transform > Deform > Twist.
In the description for potrace (https://potrace.sourceforge.net/) it also says it can generate SVG or PDF output as well. These should also work, try those if DXF format doesn't work.
