Hi Michael
Thanks very much for taking the time to respond. I've never used Deform at all until now, but I'll definitely make a start and see if that'll help me.
What I'm making is a face mask (see attached photo) and where I've manipulated all the points (so far) into the curves of the cheeks, lips, brow etc., I was originally wondering if there was a way to unify the points into set curves/paths: as in, select each horizontal "line" of points up the vertical axis one after another and apply paths so that all the points are brought into a more regimented/organised shape (so that the final solid will be smoother, as opposed to the kind of chaotic look it currently has). If that makes any sense at all.
You can see on the image that I've aligned all the points at the side along a straight line - which does help with what I want it to eventually be - but it would be great if all the curves of points could be forced into a unified path.
Thanks again, Michael!
All the best
