Boolean
11726.2
Make a straight reference curve for your spring, then make the curve line you want it to deform to
Select your spring, then use the deform flow command, select the straight reference curve first and then the curved one
This does deform the profile as you can see. If you want to make the spring profile constant then deform your helix first before you sweep the cross section to create the spring
EDITED: 2 May 2025 by GRENDEL
Size: 255.8 KB, Downloaded: 177 times, Dimensions: 1737x915px
Size: 102.9 KB, Downloaded: 166 times, Dimensions: 1063x660px
