@Pilou, re:
> http://kyticka.webzdarma.cz/3d/moi/cc/savepointfile/SavePointFile.zip don't make the trick ?
> I can't access but... save as txt,. csv,. xyz
That script will export x,y,z coordinates of selected point objects to a CSV file. It doesn't do anything for lines and arcs.
@Alex, the only thing that isn't clear is how should the output be ordered if the pieces are exploded and you have only some discontinuous pieces selected like in your screenshot.
It could use natural database order in that case, or selection order, or ??
Or is it not expected that it should receive a selection of lines and arcs that do not touch and should show an error?
