Good day.
One thing that I always think that can be improved is that when you select an item that the center is visible.
Let say I have a circle and I want to move it by the center ..I have to select it then either a command.
to move it I can select anywhere on the curve and move it...but it would be faster just to select and drag it from the center.(without needing a command)
Does it makes sense? can it be done?
Tnx!
