Numeric Keypad
11705.14 In reply to 11705.12
Hi Pilou, here's an example - when you're in the Arc center command, there is a
field you can use to set the length of the arc instead of the angle:
When you click on that field, the numpad panel will pop up right next to the
control you just clicked:
Why would you want to have the numpad pop up far away from
the control you just clicked?
