Problem creating a "solid object" (.3dm model attached)
11701.5 In reply to 11701.3
Hi Barry,
Many thanks for helping me out with the model! I'm trying to re-create what you did, just to make sure I understand how it works. Does this sound about right? (And of course, anyone else is welcome to jump in and help too!)
I've attached my clean 3DM curves again.
1. I offset the profile curve at the top, so now I have both an inner and an outer profile curve.
2. Then I Sweep each of these profile curves using the same two rail curves (see vertical ones in my screenshot).
3. That gives me both an outer and an inner surface — with or without Caps on the ends.
3a. If I enable "Cap Ends", then Moi3D only adds a Cap at the top. The bottom is still open. Is there a way to cap both ends automatically?
3b. Maybe related to the above, but I can't seem to manually cap the bottom hole after the Sweep. Any idea why?
4. I noticed you added those double lines at the bottom. How were they used in your process?
5. And from here I'm kind of stuck again.
Size: 109.2 KB, Downloaded: 129 times, Dimensions: 675x529px
Size: 130.6 KB, Downloaded: 132 times, Dimensions: 755x484px
Size: 112.4 KB, Downloaded: 118 times, Dimensions: 675x540px
Size: 140.1 KB, Downloaded: 125 times, Dimensions: 772x601px
Size: 130.6 KB, Downloaded: 118 times, Dimensions: 800x554px
