Problem creating a "solid object" (.3dm model attached)
11701.22 In reply to 11701.21
Hi Frederik,
> Is there a way to merge or “Boolean” these edges together somehow, to get a cleaner model?
> It gets very tricky to apply a Fillet or Chamfer to these tiny bits.
You can use the Merge command for that:
https://moi3d.com/4.0/docs/moi_command_reference10.htm#merge
Select the whole object, type the Tab key to put focus in the bottom XYZ input, then type Merge <enter> and those fragmented edges will be combined.
> I’ve tried creating Closed Curves from the edge outlines, but I can’t seem to use them to generate a Fillet.
A curve is its own separate object, it isn't connected to the solid.
To make a fillet on the solid you need to select edges which are part of the solid, not separate curve objects.
