MoI installing??
1170.5 In reply to 1170.4
Hi Pete
you wrote:
> Have a Ati Radeon 9520 & a Nvidia Ge Force card (not sure if its 2 - 4
> MX or FX Series) as I haven't installed it yet.
Michael you Wrote:
Great - either one of those will work fine! Between those 2, you should go with whichever one is newer, which I
think would be the Radeon in this case.
Will do!! Thanks for the suggestion.
Can you tell me if Moi will run using Windows 98SE? 98SE is a later edition
of the earlier 98. Second Edition.
No, sorry, it won't work with 98, 98SE or ME - you need to have Win2k, WinXP or Vista to run it, I would recommend XP.
Double Drat! Windows XP it will be. Thought I may be able to get around having to purchase another XP OS from M$$$$$.
Dual boot with separate HD's may be less problematic. Just a thought!
That might be easier for upgrading or modifying stuff later on... But basically if you create 2 different partitions on one hard drive they will stay completely separate that way too.
Seems like we could go either way?? Appreciate your thoughts.
> Will the design be able to be given g-codes, etc. so that I can copy these files
> to my Linux EMC and have the design produced?? Something like that??
MoI won't produce the g-code itself - MoI only generates the model data, not toolpath cutting data.
You will need some additional CAM software to calculate the toolpaths.
I'm beginning to get the picture. I believe that most Cad software does exactly what you explained. Produce the model or design then the CAM software converts this to codes so the EMC in this case can read to make the piece. or something like that???
Check out here: http://www.sherline.com/CNClinks.htm for some links to some different CAM software that sherline recommends. Scroll down the to "CAD/CAM Programs" section.
Appreciate the link. Seems that I've been looking at the CAM software for a while now. Hoping to be able to come up with a cost effective solution. You've been helpful in explaining the process. With the Moi program - PC setup - CAM will need to be now addressed. OK I think we got it a bit closer to reality.
> One PC for running Moi Cad the other PC just for the Linux EMC to run the
> Mill using the CAM part. Does that sound like a workable solution?
Sure, that should work.
Great idea & suggestions - Nice user friendly this Moi discussion forum!
Kindest Regards,
Pete
