Not snapping to grid - should it?
11693.8 In reply to 11693.7
Hi Frederick,
> I can see the benefit of having the button there but it seems odd, at least to me, that it
> doesn't also appear in one of the pages of Options that I mentioned.
Maybe. But it's also not necessarily that great to have redundant UI that isn't intended to ever be used.
> But while talking about that "toolbar" at the bottom - can the order of items there be changed by we users?
You can but I don't recommend it because you have to redo it on each new release.
But if you want to you can edit the UI, the bottom toolbar is generated from the CommandBar.htm file inside the UI subfolder inside the install.
