Hi Alex,
> if I draw a series of arcs all tangent to each other whether in MOI or Rhino and try to import the part into PIPEBEND software it doesnt read it.
Can you please post the .3dm file that has this series of arcs in it?
> If I import the same data as a DXF into Solidworks and snap each tangent with tangent lock and
> re export the same file the PIPEBEND software reads the file without problems.
If you can also post the DXF output from SolidWorks then I might be able to compare them to see what the pipe bend software is sensitive to.
There is a relatively common bug with DXF importers that they don't handle circles and arcs with a plane normal pointing in the negative z axis direction.
In moi.ini there is a setting under
[DXF Export]
FlipNegativeZAxisCirclesAndArcs=n
You might try turning that on and see if that works better.
