CURVE TANGENCY - CONTINUITY RESOLUTION
11690.1
Any advice on curve tangency and is there a resolution level within OPENNURBS ? if I draw a series of arcs all tangent to each other whether in MOI or Rhino and try to import the part into PIPEBEND software it doesnt read it.
If I import the same data as a DXF into Solidworks and snap each tangent with tangent lock and re export the same file the PIPEBEND software reads the file without problems. If I take the same arc set of curves and insert small straight sections that are all tangent between each arc and import that into PIPEBEND out of MOI/Rhino what imports AOK.
When drawing with the MOI continuity arc tool what level of continuity does it uphold?
Are these just natural limitations with the OPEN NURBS structure?
I lifted this on a quick web search.
Tangency continuity (G1) ensures that two curves or surfaces meet smoothly with the same tangent direction at the shared edge, while curvature continuity (G2) adds the requirement that they also have the same curvature at that point.
