Can "presets" for selecting objects be implemented?
11689.7 In reply to 11689.6
Hi Frederick,
> When done in code are selections going to be by name?
It can be done by name, by id value, by style assignment, by user data, etc...
If you do have the exact same objects then by id is best but if you have edited an object the new edited version of it has a different id value.
> Rather than a "preset" feature what about having a place in the MOI.INI file to
> specify a prefix character/string that would be used to identify those files to be
> exported as STL, using an "special" Export command that didn't go by selection
> status but rather by objects with the prefix character/string?
But how is a special "prefix instead of selection" based export any different than setting the selection by prefix and then using regular selection based export?
You can select by prefix currently by typing Tab to put keyboard focus in the XYZ input in the bottom toolbar, then type your prefix and then *
For example if you have a bunch of objects with a prefix BC then type Tab, then BC* and push Enter and objects that have a name starting with BC will be selected.
