MOI EXPORT STEP
11678.5 In reply to 11678.4
Hi Alex, ok so I'm understanding a couple of things better - in that file you posted
you've got the MOI generated pipe in red and the SolidWorks pipe in green.
I wasn't quite understanding that part before.
> I have had a look at both solids in Rhino and there is differences on how the the solid shape is created.
Yes it looks like the main difference is that SolidWorks generates parts of the sweep using a trimmed torus
or cylinder analytic surface when it's possible to do so, while MOI's sweep always makes a fitted surface
using the general purpose sweep refinement process.
For example the first section starting from the outside has surface control points like this from MOI's sweep:
While the SolidWorks first section has control points like this - it's a trimmed piece of a torus:
