MacBook Air M1 issue using Feb 2025 beta
11673.4 In reply to 11673.3
Hi Scott, you're welcome I'm glad it was solved.
If you want to make sure any other settings are the same you can do that by copying over the moi.ini file from your intel iMac over to your M1 MacBook.
To do that, in Finder click the "Go" menu on the top menu and choose "Go to folder...". In the dialog that pops up, put in:
~/Library/Application Support/Moi
That's where you should find the moi.ini file which is where the settings are stored.
Copy the moi.ini file over to the same location on the new machine.
Thanks, - Michael
EDITED: 14 Mar 2025 by MICHAEL GIBSON
