Spiral design for 3D print
11652.5 In reply to 11652.1
Hi Gunter,
> Once, that spiral is sorted, how would I go about creating the variable depth of the relief?
So one possibility for the variable depth of the relief could come from doing a sweep
with profile curves that have a peak and dropoff shape to them.
Something like this, the profiles point upwards in Z and it would be good to make a profile station
for every spiral turn that get smaller so that the sweep won't bunch up on top of itself:
Then select the profile curves, and run Construct > Sweep and pick the spiral as the rail to generate this:
Draw in some lines and trim the spiral so you can form this planar region:
Select those curves and run Construct > Planar to fill that area in:
These can now be joined:
Looks like this:
