Hi Gunter
The problem was caused by your outer shape profile has a kink in it , they must be perpendicular (the inner vertical point is sitting inside the next 2 )
The 3 points that make it up on the vertical axis have to be on a straight line then the fillet will work
ps it will be easier to mirror and work on parts if you work around the origin
I have uploaded redraw
cheers
shayne
