V5 beta Feb-8-2025 available now
11646.69 In reply to 11646.68
> It isn't against license terms, but it means you have your current problem where you need to do some extra setup work every time you install a new release because all of your added stuff isn't stored in a central location that can be seen automatically by every install.
- So if I periodically back up %appdata%/roaming/moi I will have absolutely everything backed up (customization, scripts, layout, etc.) or is some of that part of program files folder?
> How do you run v4 on your other computer, do you copy D:\MoIv4 over to the other computer every once in a while? Or do you have D:\MoIv4 as a network share and you run it directly from there?
- I use syncthing to sync my files and as a personal "cloud". MOI folder is part of that.
> Those buttons come from .js script files inside appdata\startup . Make sure the v5 appdata\startup has the same files in it as your v4 appdata\startup.
- Awesome. Thanks a lot.
Is there a thread which would describe what to copy where if I want to make MOI portable?
It's just more convenient for me to have everything automatically synced up.
