V5 beta Feb-8-2025 available now
11646.68 In reply to 11646.67
Hi Juraj,
> I believe it's not against license terms (it's used only by me, no other user).
It isn't against license terms, but it means you have your current problem where you need to do some extra setup work every time you install a new release because all of your added stuff isn't stored in a central location that can be seen automatically by every install.
> I got that somewhere here in the forum as I wanted to use MoI on my other
> computer with same configuration.
How do you run v4 on your other computer, do you copy D:\MoIv4 over to the other computer every once in a while? Or do you have D:\MoIv4 as a network share and you run it directly from there?
> However, I tried to copy some stuff around into appdata, but I cannot get my plugins/addons
> (whatever they are called - on the picture) to display in v5.
Those buttons come from .js script files inside appdata\startup . Make sure the v5 appdata\startup has the same files in it as your v4 appdata\startup.
