Problem with an stl file
11645.3 In reply to 11645.1
Hi Steve, the problem is that your object has some open surfaces in it, it isn't a closed solid.
To be able to be sliced by the 3d printer software the object needs to be a solid, where all of its edges are joined between 2 surfaces.
The bowl part is a solid but the handle isn't. You need to connect the handle to the bowl so it's just one combined object.
