V4 custom ui scripts and scripts full
11638.2 In reply to 11638.1
Hi shayne, that will happen if you have copied your entire v3 commands folder into appdata\commands.
To fix it you will need to remove the standard built in commands from appdata\commands, you need to only put ones that you had added into v3 in there.
