Hi Peticel, for the size not being what you expected, on line #18 of your script that currently has this:
var bbox = obj.getBoundingBox();
Change it to this:
var bbox = obj.getBoundingBox( true /* Calculate tight bounding box */ );
When you call obj.getBoundingBox() you'll get bounds that are quickly calculated by the bounding box of all surface control points.
There are just a couple of surfaces in your object that have have been trimmed by the boolean where the underlying surface's control points are a little bit larger than the active trim boundary:
If you want a "tight" bounding box that uses the trimming boundaries you need to pass in a function argument of true to the .getBoundingBox() function. There is quite a bit more calculation involved for getting the tight bounding box.
