Change view rotation with arrow keys
11635.2 In reply to 11635.1
The Following script are from resources section
Install those scripts and change 6.0 for your Number 45.0 or another number.
RotateView – this allows rotating the 3D view with the arrow keys. To do this, use these keyboard shortcuts:
UpArrow script:moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'up', 6.0 );
DownArrow script:moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'down', 6.0 );
LeftArrow script:moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'left', 6.0 );
RightArrow script:moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'right', 6.0 );
In the next script replace 30 by 0 and 45 by 0, this will help you set your view angle to Zero and then rotate with arrows .
Set Isometric
I script:var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = 'Parallel'; vp.setAngles( 90 - (Math.asin(Math.tan(30 * Math.PI/180)) * 180/Math.PI), 45 );
