HI,
You want to blend points, so you have to use blend.
The easiest way is to extrude your curves and blend using the vertical pieces.
You do it side by side and finish with blended edge and the point vertical side.
Step by step from left to right.
Next you could delete the extruded part.
The file of the sample by blending
