drawing arc tangent to 2 curves through a specific tangent point
11616.14 In reply to 11616.13
Re:
> Basically the circle tangent solver doesn't like to be given coincident
> points. Internally it's trying to generate a circle through 3 points
> which is undefined when the 3 points are collinear or coincident.
Thanks for explaining. I wasn't thinking of this command as a circle through 3 points. Was instead thinking of it as picking 2 curves and then picking a point that the tangent arc must go through. I thought the first 2 points were used to select the single closest solution if there are multiple solutions. But now I see that I'm never picking any particular curves.
Re:
> I'm not understanding this part.
Here are 2 cases where the pointpicker is in a region where there's no solution, but the closest solution is drawn.
- Peer
