Custom theme tweaks & questions
11613.4 In reply to 11613.1
Hi aphaits, for #4:
> 4. Can these icons be compacted into a group icon with a dropdown list of aligns options?
It would be difficult to do that with the theme mechanism, but you can do it by modifying the script that is generating that UI.
If you go to your appdata startup folder, there should be a script there named "Align Buttons.js" which is what makes those align buttons.
If you replace it with the attached version, it will instead make one "Align" menu button which will show the 6 align types in a popup menu.
For #5:
> 5. Can these icons be changed? Can’t seem to find it anywhere.
These are from the CustomUI mod which consists of script files inside the appdata startup folder.
The icons are set up as embedded data inside the script file.
See here for how to change it so it will get the icon from a .png file instead:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11577.2
EDITED: 21 Dec 2024 by MICHAEL GIBSON
