Custom theme tweaks & questions
11613.2 In reply to 11613.1
Hi aphaits,
For the first 3:
> 1. Is there a way to change the style / color / icon of the window top part?
That part is drawn by the operating system, there isn't anything set up in MoI to customize it.
> 2. Is there a way to change the style / color / icon of the horizontal & vertical scroll bars?
Most of the scroll bar pieces will use the PushButton colors. But there are a couple of scrollbar areas that don't have a theme symbol set up for them, they can be adjusted in the theme's moi.css . If your theme was based off the regular dark theme, there should be scroll bar stuff in your theme's moi.css , look for:
::-webkit-scrollbar-corner {
background-color:#444;
::-webkit-scrollbar-track-piece {
background-color:#777;
> 3. Which does the progress bar color affects the GUI? Can’t seem to find it.
It's shown in the upper right area of the window when loading in a large file.
Try this - type Tab so that keyboard focus goes into the XYZ control in the bottom toolbar and then paste in this:
script: moi.ui.sidePane.document.body.insertAdjacentHTML( 'afterBegin', '<moi:ProgressBar id="progress_test">'); moi.ui.findElement( 'progress_test' ).value = 25;
That will insert a progress bar element at the top of the side pane so you can see it.
Other answers to follow in a bit...
