Unit Length settings, General versus Dimensions
11612.4 In reply to 11612.3
Thankyou for the clarifications. They help a lot!
The second "General" should have been DIMENSION setting...
> If General is set to centimeters, the DIMENSION setting of ft & inches shows inch measurements. So does
> one setting override the other?
When I am doing carpentry, depending upon project, the tolerance is often 1/8 inch, or 1/16 inch.
It can also include an abstract unit of measurement called a "fuzz", which might approximate 1/16, or 1/32.
The tape measure is in feet and inches, and fractional inches.
Metric tape measures are rare, but I did manage to buy a metric one, for CNC projects.
Metric thinking is still difficult.
For the current project, I think that I will stick to Dimension Decimal setting, and avoid fractional inches :-)
I think that in one editing session, before saving, the length numbers are still fluid, between centimeters and inches (?), but after saving the .3dm, the existing dimensions do not respond to a change in general setting between centimeters and inches. (?) The saved and reloaded .3dm's Dimension DO respond to scaling.
