如何调整工具图标的间距(How to adjust the spacing of tool icons)
11606.2 In reply to 11606.1
Hi SUIYAN, usually those icons are distributed across the full width of the side pane.
If there is extra space between them that probably means there is some other UI that is causing the side pane to be at that width.
So look for things like the text on palette tabs, are there any with long names? If so that is what you would need to shorten.
