Organically curved Ring bezel
11602.4 In reply to 11602.1
Hi Gunter,
> The other way I thought was to create a surface like this and add points to push and pull to
> create the shape but the planar command doesn't work:
The Planar command isn't working because the curves are not planar. The smaller line on the bottom is slightly skewed from the x axis.
I've attached a version here that should work with planar now.
When you draw in the bottom line there can be some snaps like "Perp" that are not necessarily aligned with the axis direction.
So for example this is one you don't want:
Note that it does not have any label on the start point.
If you move your mouse around there a little more you can get this snap:
This one has an "X" label showing on the base point, that means that it is going in the x-axis direction.
