Organically curved Ring bezel
11602.11
Hi Gunter
if you generate these curves and sweep surfaces for all of the sides , you can adjust the curves to get the shape you like, every point junction must be exact to get a solid.
then join the outer surfaces and planar top and bottom to make a solid which you can can cut
