Hi Joerg,
Re:
> For most parameter/options this works very well, but there is no
> parameter for the dimension/annotation color available. You only can
> change the color after you created a dimension.
If I create a template file where the only style is Red, then when I launch MoI v5 and start drawing a dimension that dimension is red. I don't have to do anything to pick the color. Also, if I pick a different style in the middle of running a Dim command the color changes immediately. I don't have to wait until after the dimension is created.
- Peer
