Hi Peer,
Thanks for your message!
For most parameter/options this works very well, but there is no parameter for the dimension/annotation color available. You only can change the color after you created a dimension.
@Michael Gibson, Maybe you can have a look for the parameter "Mesh Angle". This one is always set to 10 after starting MoI and it is independant from what is defined in the moi.ini file. I recognized that because when checking the smoothness of surfaces or curves, I always set the mesh angle to 1 (°).
Joerg
