Open edge problem with exported STL
11597.2 In reply to 11597.1
Hi Scott, what method are you using to export the STL file, "Save As" or "Export" ?
If I move your piece over there are a couple of stray separate surface objects inside of it, are these possibly also getting written to the STL ?
Also it could make the slicer's job easier if you use the "Divide larger than" mesh setting to dice the triangles up into smaller pieces. That can help to avoid really skinny triangles that span over a large area. Like this:
