mathematically exact helix with constant radius and progressive pitch
11595.10 In reply to 11595.9
Hi geekmidget,
> Is there at least a way to force the flow tool to preserve position of control points in the Z axis?
Not for points internal to the curve.
But if you cut the curve into pieces, I think the start and end points of each piece would be preserved.
Also the fitting tolerance for flow has been tightened up in v5 so you may get better results there.
