How to find open curves quickly? and copy quickly
11594.5 In reply to 11594.4
Hi Matadem,
> If I have 2 Moi3d open and I copy an item with ctr+c it ask me for pick base.
Sounds like you have the Transform > Copy command set on Ctrl+C .
Set the shortcut's command to CopyClipboard instead.
Or you can also use the Copy button inside the Edit palette on the side pane.
