bent sheet metal 3D model for SendCutSend
11592.4 In reply to 11592.3
Decent hunches on the analytic planes and coplanar surfaces, but the same error is thrown for both these new versions.
Poking around it almost sounds like there's a kind of BRep called a "sheet metal body" and the vendor is particular about "Your STEP/STP file should contain a single, solid sheet metal body. Files with multiple bodies stitched together or assemblies will not upload successfully."
I tried a zero-thickness surface, but that doesn't work either. I guess a sheet metal body must have thickness since one of the links below says "Parts designed with a thickness greater than 0.500″ may not upload successfully."
Is there such a thing as a "sheet metal body" in the STEP standard, or are they talking loosely about sheet metal bodies that have attached parametric bend data in a CAD system's internal representation, but become standard-issue solids when exported? I'm surprised by the prohibition on solid bodies being stitched together since I didn't think that was a thing in the first place.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-F26CB5C7-A011-4C13-A2E9-F58790B8FC1D
https://sendcutsend.com/guidelines/3d-files/
https://sendcutsend.com/blog/how-to-export-a-step-file-from-solidworks/
- Peer
EDITED: 13 Nov 2024 by PEER
