setting DimRadius to Diameter by default
11591.1
Hello Michael, all,
Is there a way to edit the DimRadius command (either by modifying it directly in the .js, or by using a shortcut) so that it creates dimensions as diameter as opposed to radius ? (hence removing the need to manually change from Radius to Diameter in Details after the fact).
Thanks !
