Angle Numerical Entries Problem
11587.5 In reply to 11587.1
Hi Elang, one way you can do it currently aside from rotating or setting the construction plane is to use an angular dimension as a drawing aid.
So if you've got an initial line like this:
You can put in an angular dimension and enter in the angle for it:
Then you'll have a snap point on the dimension:
