Can't get scripts to appear on Mac.
11586.1
Is there any special process to get a script to appear in MOI? I've been fighting with making a offset of a "closed curve", and it keeps producing a "curve" which subsequently won't extrude properly.
There's a script on the forums from 2009, called CloseCurve.zip (contents of CloseCurve.js & CloseCurve.html).
https://moi3d.com/forum/messages.php?webtag=MOI&msg=2752.1
There's conflicting information on where to put the unzipped files, so I originally tried the first suggestion as to put it in the application package's 'commands' folder. Nothing changed after I restarted MOI.
I then removed the two files from the application package, and instead put them into "~/Library/Application Support/Moi/commands", the other suggestion presented on the forums.
Neither have made the script appear, so it's either something I'm doing wrong, or there's some process to activate a script.
I've restarted MOI (v4) several times, and not sure where or how I'm supposed to access the script.
Can anyone please assist?
I'm not even sure if this will fix my extruding issue, however if a "closed curve" works, and a "curve" does not, it seems like a rational place to start.
Thank you!
