Here's a script that can be pasted into a shortcut key, preselect 2 planar faces before running it. It will report the angle between the plane normals.
script: var faces = moi.geometryDatabase.getSelectedObjects().getFaces();
if ( faces.length == 2 && faces.item(0).isPlanar && faces.item(1).isPlanar )
var A = faces.item(0);
var B = faces.item(1);
nA = A.planarFrame.zaxis;
nB = B.planarFrame.zaxis;
var dot = (nA.x * nB.x) + (nA.y * nB.y) + (nA.z * nB.z);
var angle_radians = Math.acos( dot );
var angle_degrees = angle_radians * 180.0 / Math.PI;
moi.ui.alert( moi.ui.formatNumber(angle_degrees) );
else
moi.ui.alert( 'error - 2 planes not selected' );
